Help Battery life indicator
Bozzy
Member
Has anyone else noticed this, but it seems my batter "life" seems to be fluctuating based on my usage instead of the batter power i.e: If im running multiple apps my battery would go down 55% and if i kill few tasks and stop using it the batter would jump up to 65%, and its not only for the widgets its the battery indicator that comes with the phone too. One moment It was orange and less thatn 50% and after a while it went green again and looked like it was above 50%. Is this normal for android?
Not really worth making a new thread about, but I found a nice little widget called 'Toggle Data'. It just blanks out your APN, and retores it to totally disable all data.
Its really usefull when you're stuck away from a charger with only 30% or so left. It really makes the battery last forever!
