Guys...I think I've figured it out...the charger that comes with the Tab...is a piece of garbage
Recently I was getting a "use the right charger" message no matter what outlet I used. The charging would work, but VERY slowly, after playing around with it.
I was hoping it was the charger, and not a more serious issue like the battery, so I went to the Verizon store to get a new one.
The salesguy gives me the Verizon all purpose charger, and I hesitantly took it. Now all of a sudden its SMOKIN'. I can go from 30% to fully charged in like 2 hours!
I was having slow charging issues since I got this a year ago. I may have just had a crappy charger the whole timely. I can't speak for any other charger, but the Verizon one appears to be the best one.
http://www.verizonwireless.com/accessories/wall-charger/#reviews
Wow...you know when you're still using the tab while charging? With the packaged charger, you slowly LOST power. With this Verizon charger, you GAIN power, almost as the same as if you werent using the tab! I was at 95% while web surfing-a huge power drain-and the charge kept going to 100% despite that! I'm streaming video, browsing message boards...the battery would lose power with the packaged charger!
Its model #SAMTABTFL-F. Theres another model number on the plug...A36-502A. I cant believe Samsung packaged that rinky dink charger, it was slow out the box!
My next concern now is, did I lessen the life of the battery with the unnecessary long charging times? Or was it the reverse, and since the charger was weak anyway, I didn't do much harm to the battery? The way this battery is getting a full charge in about 2 hours, its looking like the former.
