Help Battery life
My s5 battery dies v quickly needing 2 charges in 24 hours. I've done all the suggested cures without success even buying a new battery in case the original was time expired.
There is a battery available with twice the 2880 mah of the original. Does any one have experience of this? Is it worth buying. It is double thickness and needs a new back panel (supplied)
Do you mean the third-party battery that comes with a special cover to accommodate its height?
It would your phone bulkier and heavier, I'd recommend a portable charger. Such charger has 3x or 4x your battery capacity and you only charge when you need it.
also maybe look into getting a new battery. if you have the original that came with the phone, i'm not surprised your battery life sucks by now.
