choffy21
Member
My experience with he droid and laptops is that you need to FULLY charge and kill a lithium battery a few times when you get it to get the full charge cycle out of the battery. My droid rarely runs out now.
Will keep that in mind.
I found that with my Eris that after several times of letting the battery hit 5% - 10% then doing a full charge overnight helped bring it up. I unplug at around 7 every morning and am at about 30% or so by 10PM. Not as good as my BB was but I don't have push email any more eitherThe manual says to, but reading about LiIon batteries, you shouldn't need to. I did.
Still worth it
ekyle said:I don't have push email any more either
I just the native Twitter app that came on the Eris (Peep is it?) and set the updates to manual. That would nullify any battery drain from that app right?I haven't noticed anyone mentioning twitter apps? I will be switching from the G1's horrible battery and would really like to know what effect twidroid has on the nexus one, say with updating tweets every 30 min or so.
Just my two cents... The Nexus 1 hasn't disappointed me. I have turned off the GPS and that seems to make a serious difference in the battery life. I noticed GPS was running when I was using the browser. Major battery killer there... after that I ended the day with 80% battery life and over night my battery drained 3%. The GPS edit is the only thing I have done and I dont use a task killer. I made a few calls yesterday totaling about 30 minutes, email on push with about 40ish received and sent texts all day.
GPS being used by browser the culprit?
Yesterday I only got about 8 hours out of my battery with light to moderate use. So far today, the performance is much better. The change I made was to turn off GPS. I've got the weather widget running, which can find you based on cell towers, but there shouldn't have been anything else running in the background. For some reason, the GPS seems to be running in the background almost all the time if turned on.
shouldn't the GPS only be running when you see the little satellite dish icon flashing in the status bar? that's what I wonder...![]()
i leave it on, since i like having my weather location update on the fly... location/gps doesn't seem to even show up on the battery usage page...
.... I still leave it on though... (different handset though)My experience with he droid and laptops is that you need to FULLY charge and kill a lithium battery a few times when you get it to get the full charge cycle out of the battery. My droid rarely runs out now.
Does that come standard on the nexus one?
Run it dead. So dead you can't get the phone to turn back on.
Either way, frequent long drains and deep charging cycles is a no-no and I wouldn't recommend it in the early part of the battery's life.
