Well depends on how much usage you are using, and depends what apps are running, also on your signal strength, there are many factors. I would post your question here and I am sure someone will better help you there, http://androidforums.com/samsung-galaxy-ace/
If you are a heavy user (like me) then that is one of the few reasons you have to charge it so often. Another reason is that you may just have a defective battery and you may need to replace it (this is a common thing with these batteries). I currently have six extra batteries and zero battery stress.
I really don't think there is any way to reduce battery consumption other than to have the device charging at all times. Or get one or two extra batteries.
