deathstrike
I just got the rise and my battery went from a full charge to 8% in about 3 hours i turned mobile data off and battery doesn't drain is this normal.
My battery goes from 100 percent to 4 percent in 5 hours. That's with my screen on lowest setting and using Juice Defender. Anybody able to beat that?
Same situation here. In the beginning Juice Defender was working great. A full charge lasted me atleast a day. The only suggestions i really have..which you may have already tried. check your running apps under battery every once in awhile after using mutiple apps. force close what u dont need..i personally dont use live wallpaper as it kills kyocera rise battery quick. also widgets will drain battery VERY quick. hmm...cant really think of anything else...anyone else have any suggestions as im curious myself...this is my second kyocera rise. first was deemed faulty device by tech support..so got a replacement and battery life is just impossible..i use chrome as my default browser..and i do alot of browsing. any suggestions on a less RAM and battery hog browser?![]()
