Is this battery life normal? How is everyone else's?
I'm using CM10 and out of those 2 hours, I had my screen on about half the time to answer various messages and check email. And for Min frequency, I have 192 MHz whereas for max, I have 1242 MHz. I don't know if that's what you mean by cpu settings, though.
4g does drain battery pretty fast but it shouldn't drain like that. What governor do you use?
"ondemand"
Something definitely isnt right if after 2hrs ur at 23%. A few things 2 consider...Reboot into recovery and try wiping only your battery stats, then reboot. Also how old is your phone? Maybe ur battery is getting old? U can find new ones for relatively cheap. Your settings dont seem like they should be affecting your bat. life that much.
Well, I see mediaserver is taking quite a bit of juice... Were you streaming music or listening to offline music?
Both will keep the data connection active and you'll see a gradual drain like that. I see battery stats like that when I stream Sirius at work... And my battery lasts about 2 hours doing it too.
This is what I get with moderate use:
Its a lot worse when I stream on 4g/cdma.
I've been using the Spec2 battery. About a three hour gain after replacing the original that's about 9 months old. I'd say average of two. Also, still on stock ICS debloated running FB. Lasts the day with moderate use, not too bad.
My 2 cents on the subject of batteries for the spec - http://androidforums.com/lg-spectrum/671780-extended-ebay-battery-better-than-stock.html#post5425854
...for whatever its worth...
Didn't want a bulky one. So I read. No I'll effects at all.
Do you think it'll be better to go with the Spectrum 2 battery or the extended one?
Well of course I'm biased toward the extended for $15![]()
I didn't really notice the bulkiness myself, but then again I came from having a gel cover, which made my phone a little thicker.
Barely thicker...
