Battery Life
  • Start date Start date
A
Android Question
Guest
This is not question...this is an advise
Why buy the phone (Android) which is having a battery problem?
Especially when people talk to manufacturer and they advice to make lots of functions OFF, low your brightness, considering usage of GPRS and so on....
Are the manufacturers foolish? They don't know that we are giving features to use not to make it off or controlling use.
In short, manufacturers have to focus on the battery life first as THERE IS A LIFE THEN THERE IS A NEED.
Hi and welcome
The best way to influence manufacturers is to vote with your wallet - as you say, if you don't like the look of a particular product, dont buy it.
Regarding power saving, its only like suggesting that you turn off your cars engine and headlights when you leave it parked - it saves power (and is normal behaviour)
Roger
