Battery low Cannot program
Andrug
I was trying to SBF my phone and the battery died. In boot recovery it tells me battery low cannot program, even if its plugged into the CPU. What do i do?
thanks:D
Can your phone charged while off? If so power it off and let it charge, wall outlet would be best as it will charge faster than USB. Once it is charged you should be able to SBF the phone. If you can't charge while off you may need to get an external battery charger to charge the battery or find someone with the same phone as you can use their battery.
Check the related forum for your phone. I know you have a moto phone but I don't know if you have a D2, DX...
