novemberwhiskey
Does anyone know how to get the battery manager back if we are running Liberty?
Is it an APK?
Is it an APK?
There is a battery manager, it's just not in the settings menu.
If you download the Clarus Battery widget, put it on a homescreen, then press on the battery percentage on the widget, it'll take you to the battery manager.
I see two files for battery manager in my Titanium Backup folder.
Is there another way to access the battery manager?
I don't mean the screen that displays the battery use; I meant the manager that let's you set night-time mode profiles (turn data off etc.)
