Battery modes?
funkylogik
share the love peeps ;)
Anyone know exactly what power save, balance, performance options actually do (to the cpu etc)? (cm12s)
I am not sure of most but I believe if you select power save, it stops most push notifications. I believe if you select that option, it gives you a warning about it. I do not have 12s so I cant verify. I remember my wife complaining since it made her not want to use power save.
Excellent info Cafe cheers mate. Just what I was looking for. Strangely (and I know benchmarks aren't really worth a shit) balanced scores higher on AnTuTu and Quadrant than performance.
EDIT Ahh just reread your post and it's just running a performance governor so that explains it. Same max speed as balanced :thumbsupdroid:
So what mode is everyone here running most? I usually use balanced but lastnight my battery was dying and I put on power save and the drop in performance didn't seem too drastic
Just realised "power save" also shuts off two cores
