Help BATTERY NOT CHARGING
  • Start date Start date
A
Android Question
Guest
HI,
my htc Desire 826 Dual SIM mobile battery is not charging
  • replaced new battery
  • brought new htc charger
  • USB connector also fine
PLS HELP ME
Well if you've eliminated the charger and the battery that only leaves the phone. That's all I can say: there's probably a fault in the socket (one you can't see) or on the board.
ya sir socket is also fine, glows indicate light , its shows only 0% charge
What type of cable are you using ?
If the battery is brand-new or completely discharged, you will need a powerful charger and a thick charging cable to wake it up.
Make sure your charger can deliver at least 2A and a good quality charging cable, not the cheap and thin cable.
yes sir i m using 2.1 amps output cable , condition is same 0% charge
Do you have other phone or tablet with comparable battery capacity to make a test with that charger + cable ?
