I like Thom's idea of a wipe of the cache partition. That said, Android OS using battery in a relatively unused Turbo I think is perfectly normal.
I'm not sure how old your phone is, but it could be battery fatigue that is causing a perceived loss of battery life. The more charging cycles a phone goes through, the more it deteriorates. If you bought a Turbo close to the time that it was introduced, which was nearly 18 months ago, I'd say it wouldn't be surprising that the battery is not lasting as long.
For what it's worth, the lithium ion batteries in phones last longer when they have more smaller chargers rather than fewer deep charges. Rather than trying to make the battery last for days, the battery will last longer if you charge it more frequently. While I know that Verizon marketed the phone as having a battery lasting up to 48 hours, that doesn't meant that this is a smart way to use your battery. I'd say that if you can find some time every day to give a little charge to the phone, the battery will last a bit longer.
My phone is just a year old. I thought that charging it often trained it to not last a long time. But maybe that's old school and older phones that we used to have. I'm anal about getting as much out of each battery charge.
A partial discharge reduces stress and prolongs battery life.
Do not discharge Li-ion too low; charge more often. A random or partial charge is fine. Li-ion does not need to be fully full charged as with lead acid.
Yes, that's "old school". It has less to do with older phones than with battery technology. Lithium based batteries do not have a "memory effect" like older Nickel-based rechargeable batteries do, but I can't think on any phone made in the last ten years that wasn't using a lithium based battery.
Here's a lot more information from Battery University: http://batteryuniversity.com/learn/article/how_to_prolong_lithium_based_batteries
Key quote:
Also: http://batteryuniversity.com/learn/article/how_to_increase_the_runtime_of_your_wireless_device
If you are keeping your phone on your desk at work, it would be smart to have a charger there (if you can) and pick a time when you'll be at your desk to charge for a period of time every day. With the rate you use your battery, it probably doesn't have to be much more than 15 to 20 minutes, particularly if some of that charge is a turbo charge. Or if you commute by car, plug in while you are commuting. As it turns out, it's probably better to be anal about charging that way than trying to get the most out of every charge.
Even a year is long enough to show some battery deterioration. Battery is probably one small reason why phone companies started with two or three year contract cycles for phones - they knew the batteries wouldn't last that long (though the increase in other phone technology is probably the biggest reason...)
) your phone will consume more power trying to maintain the connection and it will show up under Android OS in battery stats.If this happened all of a sudden, then it's quite possible that a process is 'stuck' on and showing a drain through Android OS. Most times simply rebooting your phone will take care of this. As Thom suggested, clearing the system cache won't hurt either. I would suggest you do this from recovery rather than using a cache cleaner (That's just my preference, YMMV)
Are you having WiFi issues? I just mention this because if your access to WiFi gets weak or 'wonky' (<< technical term) your phone will consume more power trying to maintain the connection and it will show up under Android OS in battery stats.
One other thing to consider, if the drain is not uniform, in other words, goes from 80% down to 40% in a short period of time, it could be a cell in your battery is failing.
Last night, it drained from 100% to about 35% in a matter of hours. And the phone was hot-- 100 to 115 degrees, even when not being actively used. (This extreme version of the phenomenon is very recent-- just yesterday.)
I've done a Partition Cache Wipe. I just tried the hard reset like @Thom suggested.
Side note: I run GSam battery meter, and indicates that the majority of my battery power is being used by apps. And of those apps, the greatest one-- by far-- is e-mail (the stock e-mail app).
