Help Battery % on right hand side of the status bar (in white)
OcalaFlGuy
Android Expert
It actually seemed to just appear in the past couple days and believe it or not, I want to make it go away. (In white on the right side it looks all jumbled up. I already had a decent green battery widget % on the left side.)
I also just noticed this on a Screen Shot of Sammyz Motion.
How can I turn it off? I've gone thru the just couple apps that might have put it there and can't find it there or in the system tray.
Thankee in advance,
Bruce in Ocala, FL
NM, found it, (PS; it's the Battery % not the WiFi) it's in Settings/Power Saver, a toggle.
I've been in and out of the Power area a lot lately taking battery use readings and must have accidentally enabled it.
Bruce in Ocala, FL
