Battery Parameter Upgrade Wizard
xclusive585
I am curious what the "Battery Parameter Upgrade Wizard" program does. It can be accessed and run with aftermarket launchers (like launcher pro-activities) and I'm sure could be found *somewhere* with a rooted phone and root file explorer (I'll find it's location and update later). On my android it's never ran by itself or on command by another program (that I've seen anyways). Out of curiosity I ran it, it seemed to update several hundred "commands" or "parameters" pertaining to the battery.
On the entire web there is literally nothing to be found about this program and I was wondering if any developers or hackers around here could shed some light on the subject?
Im running Froyo, rooted, minimal modifications, and launcher pro.
