Is this possible?
I use the app "Battery Status":
http://bit.ly/v0THZ2
You can customize the icon that goes in the status bar. I set mine to "Large white numbers, no background", here is what it looks like:
(notification in top left corner)
uninstalled, it obviously doesn't work with the VZW SGN.
It works great on mine!!!
Can't access the app, does a weird 4 panel screen, and leaves a little animated thing (about 4 px) on the left edge of the home screen.
It instantly put up a battery icon with a number and over and over and over did alerts saying there was a change.
