Help Battery plummeting even whilst plugged in!?!?!?
stevep94
My S2 is usually OK battery-life wise but last night I came to my phone and it was off and wouldn't turn on until I took the battery out for a few seconds and tried it again.
I didn't think anything of it and turned it off and plugged it in overnight as I usually do.
Switched it on this morning and the charge was sat happily at 100%! :)
Anyway, half way through the morning I noticed the charge had dropped to 85% having not used the phone at all (which I found a bit odd as it usually sticks at 95%+ until at least lunch time if I'm not using it) so I've plugged it in to my cradle at work and let it charge back up but the next time I look about an hour later, its dropped to 65%!?!?!?! :confused:
Has anyone had a similar problem and more importantly, know how to fix it????
Thanks.......
