Help Battery Question
El Presidente
Beware The Milky Pirate!
I'd to battery pull the other day because my WildfireS locked, I noticed the sticker thing on the bottom of the battery was bright red. I'm pretty sure I would've noticed it before because red on HTC handsets normally means water damage. So, is the sticker on everyone elses battery red or white?
If you're not sure what I mean, here's a pic:
Mines white mate. Looks like youve got water damage but on the bright side you still have your one x.
Also i wouldnt reccomend using it anymore until you get a new battery as it cant be very safe.
It's my work phone and I'm on leave until January anyway so it'll be switched off for a while. I'll see about a replacement when I get back.
Cheers for the info. :)
