i have a samsung transform ultra from boost mobile. It currently has a 1500 mAh battery. Can i get a higher mAh (like say 2050mAh or even 3500mAh) for my phone!!! Thanks Tina
Hello. I see that there are extended life batteries for your Ultra. You will need a replacement back for the larger capacity batteries are thicker. By doing a quick Google search I find an extended back for around $15 You can find these things online or go to your local provider outlet. I hope this helps.
