FYI, when you need a battery for an Android device, just enter the model number of the battery itself (printed on the actual battery) into your search bar in your browser and search it.
Disregard any info that comes up about whatever device it may fit- if the model number matches, then it is the same battery.
Stay away from e-bay, and that sort of thing.
I have had excellent luck with Amazon.
