Root Battery Rom Combonation
Hello! I am looking for a good Rom/Kernel combonation that is good on the battery but not too terrible on the performance. Anyone have any good ones? I have been trying some Roms out and they all to seem decent but I just want to know if i can get any better. Thank you!
I get very good performance with trigger and overstock (not oc'd).. I have noticed that my battery life went down some with the current version I am running but there are updates for both that I am going to try as soon as I get dome time. Previous versions were giving me well over 48 hours with light use and would get me through a whole day with moderately heavy use. Whatever that actually means. Not only is my battery life not an issue for me anymore, but this combination runs smoother and just feels better than anything else i've tried. I have not tried any other roms for a while though so I can't really compare to any newer releases out there.. but that is how happy I have been running this.. Triggers included apps are uninstallable unlike some other roms and the bloater app is a must have for any rom!!
i'm using axura.. battery life is significantly better than it was on stock (at least 2.1). with 3g turned off, i can get 2-3 days with light use. one time i got 5 days of light use, but once i took the battery out (soft reset), the battery life hasn't been as good.
and compared to 2.2 (i had it for a week), it feels significantly faster.
