Battery saver prevents interval mail check
joboy
Member
Hi there,
I am using a Moto XT701 running on Android 2.1, and I have interval mail check every 5min., to reduce battery drain I installed a battery saver, but since then the interval mail check failed to work, even when I refresh manually the 3G link won't go up, until I refresh many times, is this normal ?
Now I installed a task killer, to auto kill background apps that not running, this reduce battery drain and memory usage, but I still want a working battery saver that will take care of the mail check, I have such thing running on a Nokia and worked wonderfully, I suppose Android got similar thing as well but I can't find it yet, any advise ?
I have the same problem.
Before installing the Easy Battery Saver App, I used to receive notifications of emails from my gmail account.
Now, I never receive notifications, and I can only see if I have new mail by refreshing the inbox several times. Is there a way to re-introduce a mailcheck, even if it is an infrequent one?
(I'm using a HTC wildfire S)
