Battery saver apps depends entirely on your usage pattern. Most of them just toggle the network connection in a given cycle. They do work if you keep the mobile network turned on. But if you manually toggle them as needed, they won't do much.
Hi Chan.
Thanks for your reply. But, I keep my mobile network turned all.....so....I'm in need of a good battery saver app.
Hopefully somebody can share an app that has worked for them.
Thanks.
