For those having problems with their battery life (and are rooted and not scared of a little tinkering) here's what I did to save battery. It helps a lot, and while the battery is not a good as it was on ICS, it's better than after the update.
One: Make a complete backup of your current OS using CWM recovery. Make sure to do this, or you're stuck if you wish to revert to the OS before this tweak.
Two: Download Titanium Backup and uninstall Google Maps, Google Search, and Google Plus. I found that these three apps are the biggest cause of idle battery drain
Three: Reinstall these three apps from the Play Store.
Four: Download Greenify and select those three apps to be greenified. They won't run in the background unless you tell them to, and thus they will not use battery.
This has worked fairly well for me and has helped to increase my battery life by at least a half.
