battery saying at 100%
raven_go
Since I last checked my battery over 18 hours ago, the battery has stayed at 100% which seems very odd to me, does this happen to anyone else?
man i knew the battery on these little devices were good but 18hrs and still full!?!?!?! i think i go jipped! mine goes way lower than that in 18 hours! :D
My first one stayed at 100 for 11 hours once. Of course I didn't even touch it in between then.
18 hours is crazy. If you aren't using it then maybe but a reboot would probably fix it if it's an issue, like others said.
Mine does that occasionally, staying at 100% for ages then quickly draining to 87% or less, and it even went though a stage where every time it said it had 50% left it would shut down as if it was totally drained. Its currently back to normal after charging it a few times while completely powered off.
I don't think the charging circuit or battery meter on the Nexus 7 are very good.
I have heard lots of cases of strange battery behavior.
