Battery stats
lunatic59
Moderati ergo sum
Moderator
Anybody else having trouble getting reliable battery stats?
My G4 did this and I'm led to believe it's an issue with other LG flagships too.
Per chance when you take it off the charger, does it stay at 100% for what seems like an age, regardless of what you do with it, then start losing charge normally?
usage on battery
1h 35min
Does this still occur 4-5 hours after removing it from the charger?
I have a different phone, but for the first couple hours it wont show battery data. I assumed it needed sufficient stats and time to show all info.
Decided to test this after charging, after 2+ hours it still didn't display info.
Once the battery dropped to 98% then it started showing stats. Your screenshot shows 99% so maybe Android waits until the battery reaches 98%.
My battery last all day and can go into the next day. Very satisfied. Don't have to walk around with a charge anymore!
While I haven't been off a charger for more than a few hours, I am seeing very good batterly life so far. It does tend to hang out at 100% for a long time before starting to drop, but I am going to chalk that up to the LG reporting method.
I'd look into what actually is consuming your power and how you are using your G6.
