cronusSmith
Hi,
I recently sent my Galaxy S to be repaired as it was dropped in water. When it returned it had been updated to android version 2.3.3. The battery life seems to be worse than before and when i go to settings->about phone->status the top option "Battery Status" states that the battery is "discharging" when in normal use whereas when it was running Froyo it would say "not charging." Is this a problem with Gingerbread reporting the wrong status on this phone or is it a battery/charging circuit issue. As both have been changed I cannot pinpoint which one is causing it.
Thanks, Cronus
Thanks, Cronus
