So I got my hands on a problematic OPO a few days ago that wont charge at all.
It wont charge when connected to the wall charger nor when plugged in a PC. The only way the previous owner was able to charge it was taking to a phone repair service where they would just take out the battery, charge it using an external battery charger and put it back in. Then the phone shows 50% battery all the time, never goes up or down, and lasts around 2-3 days. The owner got tired of visiting the repair shop every 2 or 3 days to do that and handed it over to me. I thought the USB flex cable is the problem so I ordered this one: (oops cant post links) to replace it but it wont be here for another 3 weeks.
So these are the facts so far:
Any ideas on where I can find an external battery charger(not a powerbank)? Ebay and Aliexpress don't seem to have anything like that.
Did I make the right choice ordering that flex cable or did I only waste my money?
Any ideas as to what the problem might be? Anything I can try at the moment?
Thanks in advance
Best regards,
- Battery has been replaced, so its not a faulty one(or so I have been said)
- Charger and usb cable are OK as I have tried a few different ones.
- Phone connects to the PC and can browse it for files.
- When switched ON and plugged in battery says "Not Charging"
- When switched OFF the green battery animates to 100% but never goes up more than 50% permanently.
Thanks in advance
Best regards,
