Falchion
Member
So my battery life has never been anything but spectacular until very recently. I used to be able to last 1.5 days with casual - moderate usage but now 9 hours of very casual use seems to completely drain the battery. In addition I can only charge it to 90% for some reason, I guess one of the lithium cells died or something. For the time being I've uninstalled a huge amount of apps, deleted most of my widgets, and I monitor apps to make sure they aren't draining my battery but this is more of a band-aid approach and not solving the problem.
Anyways is there anything I can do to improve its life or do I just need a new battery completely? If so should I try to get just another stock Atrix battery or are there some nice extended ones?
Thanks!
Thanks!
