Help battery test
D
Deleted User
Guest
I thought I'd perform a battery test after updating to 026. I'm very happy with it. With WiFi and gps switched on and screen brightness on its lowest, after 24 hours I have 63% battery left. I've called a few people, sent texts, no emails, and used sat nav. Also played doddle jump a fair bit too. Anyone else get battery life like this now with the update?
I got a whole 48 hours with wifi and gps on while still using my phone normally, the new update has done wonders for battery life.
hmm.. after 12 hours it's a 79%...gps, wi-fi, a few texts and call, maybe 30 min of various low end games (text racing, dominoes,tilt labyrinth). and some browsing...
did you had to root it to install the 026?
Nope, you just need to debrand if you can't already get it on SEUS.
Mine uses up 20% for 24 hours on normal use (I send on average 35 texts a day, make a few calls and browse the web for maybe 10-15 mins), heavy use it'll be down to 50% at the end of a 14-16 hour day, which is still pretty good IMO.
I go a long time with 020. I can go three days with light use or two with moderate use. I could probably push another day out of it if I went down to zero too.
I'm not a huge user though. Check the weather here, use an app there, some MP3 for an hour, Endomondo while working out and a bit of surfing is as much as I use it.
I'm at 37% after 30 hours....i'm running 020.. GPS on, WiFi on, i used nav for 15 min, browse the web for maybe 1 hour, as i said earlier quite some time playing low-end games, listening to music (maybe 2 hours). other than a few texts (maybe 30) and about 2 hours of talk time. Brightness is still at auto setting.
If it takes you 10 hours to charge then there is something wrong with your charger or even battery. Over heating maybe.
Anyone here rooted? Do you get good battery life?
can u tell me wot apps etc u guys using i.e juice defender ect,
iv jus got the 26 update and get around 14 to 16 normal use with wifi on a little, and bout a hr use of internet,
only app i use is juice defender which im not sure if its helping or not, seem to work for me on 16
a weird thing happened today lol...
took it off charge this morning @ 6
was fully charged
i checked @ 4h30 pm and still 73% lol... kept it turned on all day long, normal use, some facebook, msn and call...
maybe the battery needed time to get used to...
I was using juice defender and app killer, but I heard they were useless. I turned off Juice Defender last week...my battery life is completely unchanged.
I only use the App killer widget once in a while. I don't keep the program running.
I found Juice defender to actually worsen battery life.
Ive rooted and Im considering going back to a rooted phone with the 026 update.
Since Ive stopped using appkillers and just let them run in the background like they apparently supposed to on an android phone, battery life seems to have stabilized???
But then again I always charge my phone overnight, habit now. By end of day one after normal usage, I get home to about a 50% battery mark...
Mnnn maybe I shoudl try the 026 firmware rather...
I gave up after 40 hours it fell down to 5% i guess i played games a bit too much. I used task killer only twice to kill mediascape mostly. It charged back in less than 3 hours. I plugged it at 6pm and at 9 it was fully charged
