depends on what you're doing with it.I just got my Galaxy 3 this week and I'm getting about 6 to 6.5 hours of battery time if I use it pretty much nonstop. I've seen people talking about short battery times, so I was curious if what I have is normal.
You think 6 hours of non stop use(I'm guessing screen on) is short, and should last longer?
Jesus christ people are more anal about their batteries than anything I've ever seen. Use it less, I mean theres 24 hours in a day, and you sleep for 8, which leaves 16 hours. Almost half the time from when you first wake up, you're on your phone.
http://androidforums.com/samsung-galaxy-s3/618583-truth-about-your-battery.html
Try installing the Juice Defender App, increased my battery time by half. It mostly helps with battery life in idle mode though.
Another thing to do is to check the sync settings of various apps and accounts, frequent syncing eats battery life.
Thank you for the link. I'm still reading through it (it's definitely answered or dispelled some notions that I had).
Regarding your point about the Juice Defender, it says that it has saved my battery by 1.35 (I'm assuming that means by 35%). Is there anything misleading about that or is it actually helping?
I highly recommend an extended battery. I have an Anker 4400 mah in my phone, my wife has a QCell 4300 in hers. We easily get 2 full days of use out of our phones. The extended batteries take the S3 to another level.
I get not wanting to be anal about the battery, but at the same time, you want the battery to last as long as realistically possible so you don't have to charge it more when it's midway through the battery charge.
What I'm trying to say :
Let's say that my battery is at, say, 50 %, and I'm done using it for a little bit, but I want to make sure it lasts when I use it again, is it ok to just go ahead and charge it up? In other words, does it not really matter how often I charge it?
Also, what's a reasonable amount of battery usage when the phone's asleep. Generally, I've seen about 3% used when in sleep mode. Today, after about 8 hours idle, I woke it up and it was at 94%. I just wanted to know if some variance is okay, that, given about the same amount of sleep time, using up 3% or up to 6% is normal. I'm wondering whether I may have changed a setting which caused it to use up more battery when in sleep mode. Thanks.
