Battery usage bug, doesn't reset
kuechi
Still runs and doesn't reset to zero
It has been 3 days(also my phone is 3 days old, SG2,international model)
And i already charge it 4 times, i only get like 8 hours of usage
and to think that every charge it will reset the process, why doesn't it reset?
is this a bug
please don't suggest me to root
I am done with the jail breaking stuff
That's not normal.
Did you hit 100%?
In the worse scenario, you'll have to reset your device to factory default.
A Galaxy S2 could have an 8hrs battery life normal DEPENDENT ON SETUP AND USAGE.
Are you connected to your network internet 24/7? How is the signal in your area?
Do you have background sync enabled? What apps you do you have that sync? How often are they set to sync?
How often do you use your phone? How many hours of browsing or playing games or calls?
Each of these has a factor, and a pretty heavy user can run down a battery quickly. Some days I can get from 6am to 6pm with 50% reduction in battery charge. Some days I run through my battery in 4hrs.
