Help Battery usage only shows screen
skodialk
Hi,
I have a Galaxy J5 with android 5.1.1. Today I decided to check what is taking most the battery juice but in the battery usage section is shown only screen usage /which is 100% of used power...see the attached pic bellow/.
Can I fix it somehow to show all apps that use power?
  • Like
Reactions: EGH
I'm too having the same issue with Galaxy J5, I've been looking around a little for the couple of weeks I've had the phone but had no luck so far.
I tried to clear cache and restart phone no luck so far.... the stupid thing is that google returns lots of crap when you serach android + battery usage ... :(
I also have this problem, but only from today. Suddenly phone began to eat away at the battery terribly, so I wanted to see which application does it. Previously it showed correctly all applications, not now :(
This seems to have been resolved in the latest software update :)
