Help Battery usage?
Hi guys, thought i'd start a thread for people to discuss their battery usage on the One X.
For example, my battery was at 82% when i woke this morning. i checked facebook for about 5 mins, sent a text and it had dropped to 75%, roughly a % per minute of usage!
And this is AFTER applying 1.28....
Anyone else got similar battery stories/issues?
The battery seems to take a couple of minutes to update itself on my phone so sometimes it is like a false reading as it will drop 5 or 6 % like yours but then if you keep using it stops dropping so quick. This normally happens when left idling for hours
I had big issues with my phone after the update. It would not last the day. I checked here and found some similar issues. It was mediastreamer that was causing the problems. Did a soft reset and all is now fine.
I had pretty crappy battery life since the first day I got my phone, I usually need to charge it again during the middle of the day.
And by 'soft reset', do you mean holding the power button and selecting reset?
I am quite a heavy user for phone functions and a little internet but that about all at the moment. It lasts the day.
A soft reset I meant a reboot. Turn it off and on again without fast boot enabled.
