Battery Widget Viewer For Testing
gunnerwing
Feature
-Display status battery by status real time
-Display plug in widget for charging mobile
-Can set alert message for battery low
-Can set vibrate mobile for battery low
-Can set status battery to aleart or vibrate enable mode
-Open/Close Wifi
-Open/Close Sound
-Open/Close Bluetooth
-Open/Close Gps
-Display Status use battery then click Battery Image
-widget sizes 1x1
-widget sizes 4x1 (Support HVGA and WVGA)
Support
-Can use this Widget on mobile Android Version1.6up
Thank you for test i app and this the first project in android my life ^^
WebURL: https://market.android.com/details?id=com.roommate.app.widget&feature=search_result
Mobile QR
First off, this is a very sharp and clean widget with a nice easy to use UI.
Now... Upon placing the widget on my Home Screen, WiFi was enabled (I rarely use it) ,Bluetooth was enabled and my Data Connection was automatically disabled. It's not apparent if the app is designed to change these features upon install but it is not a wise choice in my opinion.
Other than the initial install operations that were preformed, this widget is nice. I would consider some more options to compete with other comparable widgets but overall the app is clean and easy to use.
G2 - Rooted with Villision 1.0 ROM
