battery widget
foxII
There is a horizontal battery widget that displays the % inside it. It is usually blue. Anyone know which one this is and if its free?
I wish i could help ya but i think that most of the good ones are paied but cheep and i know that one i uses changes colors with the prectnage and i use battery indicator pro and the light version its self is still nice and both are very accurate :D
Your either thinking of battery left or battery life. Both are nice, I like batteryleft because you calibrate it to your battery and it displays the % in 1's and gives you an estimation on how much time you have left.
Thanx. That one works.
My next question is for power control widgets (i.e. the five square buttons that activate wifi, bluetooth, internet,ect) is that already on the phone or do I have to buy it?
some of the switches are on you phone use the widget shortcut and if you want control over all of the switches i suggest you switchx Pro
Thanx. I have the free version of launcher pro, will switchx pro interfere with it, or should I get launcher pro plus.
Also paypal does not work with launcher pro plus.
oh yeah, and what app do I need to scan the square digitized barcodes, or does the evo 4g already have it.
I tried to move them directly on the Evo.....no luck
I tried sending as an email to myself..... You would laugh when you see the results, no luck.
I tried downloading to my computer, but they come up as XML files and dont know what converter to use (tried pchop, adobe reader, picasa)...no luck.
I tried downloading file manager and placing them in a file for export to gallery....no luck.
Anyone have a sure fire way to accomplish this?
