Hello All,
In the middle of the week my battery was acting quite erratic, its power was dropping quickly, then without charging rising slightly. Then when inserting the charger it was saying "USB cable connected" in the notification bar but wasn't charging, however if I turned the phone off, inserted the charger it would charge even if I turned the
phone back on. If I then removed the charger and reinserted it straight away it wouldn't charge. I was out of the house most of yesterday and my phone ran out of battery, now when I insert the charger it turns on brings up a critical level of battery message and then turns off. If I leave the charger inserted it will contintue to do this on a loop until I remove the charger so it must be charging slighty.
Any Help would be much appriciated.
Many Thanks
Anthony Mullins
Many Thanks
Anthony Mullins
