Help Battery
I try my best to explain.
So i changed my i9070 battery because it gone bloated. Everything was okay for the 1st week then it gone weird like the battery icon show half green then it suddenly fade out to 0% all of a sudden. When i try go to the shop and ask what happen they say the charger port might be problem. They suggested me to buy a special battery charger where u take the battery out and charge it at the plug.
then it started.
when im using the phone around 10-30 min the phone will suddenly go off even at the 70-90% charges.
when i power on it back it will be between 10-50% . and charging a 10% battery will be FULL in less than 30 min.
i think the battery is the problem because it seems not really fit into the square cases. but i also think it might be the phone problem(i been using the phone for 8 years)
please help me . (sorry if i explain badly:()
Your phone's battery need replacement. The lower capacity the battery has, the faster it will die.
But i just bought it a few weeks(maybe month) ago... when i buy the new battery what should i do and dont so i dont lower its capacity
Maybe it's a low-quality battery? It took me 2 attempts to get a decent one last time I replaced one, the first (from a store I'd dealt with before without problems) turned out to be a fake, hard to tell by sight but the battery temperature always reporting the same value regardless of usage was a give-away.
Yes many OEM batteries are of very low quality. And most of the time they don't have a working NFC antenna like the original batteries.
