Battery
erudite
I have just purchased a samsung galaxy s2& I'm very pleased with the phone apart from the battery life. Every review I have read has said the battery life is very good but I'm struggling to get a days life out of it, any tips to extend battery life would be appreciated
Welcome to the forums :)
A lot of people use an app called tasker to help set up "profiles" to save battery. It has a bit of a learning curve though. You can also use widgets such as the Android power control widget (long press on an empty spot on your screen choose widgets > powercontrol) or an app called Quick Profiles.
Also, to see what is eating the battery:
(from your phone's home screen) Menu > Settings > About Phone > Battery use
Usually the apps at the top should be something like:
- Display/Screen
- Cell Standby
- WiFi
- Phone idle
