Hello mappon and welcome to Android Forums. Battery loss is a sad fact of all the smart phones to some extent. There are some things you can do to help with battery life. Make certain you have a solid internet connection... if not you might consider putting your phone into airplane mode until you are in a solid signal area. Check to see how often your phone is auto syncing with your social/mail/and apps.
You can limit the frequency of updates and sync will save battery.
You might consider checking into your phone's home forum for more device specific advise. Here is a link to the list of Android phones and a link to their area of discussion. Good luck on your saving battery life quest and thanks for joining AF. Android Phones - Android Forums
