Battery
Hi, My battery on galaxy s2 is very bad. i have to charge it everyday.
Unfortunately, it happens. You might have a battery that has gone bad. Try replacing it and see if the new one does the same thing. Also, stop in to your device's support forum for some tips on how to get more power out of your battery. (Btw) Welcome to Android Forums. :)
Best of luck.
P.s You can get some cheap batteries on EBay or Amazon.com
