Depends on how much of an appetite for the placebo effect you have. Just get a decent charge and use it.
I'd recommend a full charge to start, but only because you will spend a good amount of time on the phone checking out various features and setting things up.
And try not to let it go under 5% or so. I know some people let it die before charging the back up the first time but that can had adverse effects on the battery.
it should be done at least once though, in order for android to be able to tell the actual capacity of the battery. whats the use in having a battery that lasts ever so slightly longer if your phone thinks its almost out of energy before it actually is?
