battery
  • Start date Start date
A
Android Question
Guest
i spent quite a bit of money on this phone and it goes dead so fast why?
Hi and Welcome to the forums
Is hard to comment without knowing which phone you have! The most common reason for quick battery drain is leaving the mobile data connected all the time and/or leaving gps connected (ie. An app using it)
If these are on try to keep them off when not needed.
If you install Gsam battery monitor you will be able to see what is causing the drain.
Roger
