batterybay.net extened battery next week
laz818
Member
I got a email from bb.net next week they will announce whether they will produce it or not most likely they are because the details that they give me it will be 3500mah with the cover at unbeatable price what they told me
There is already a 2500 mah battery for this phone a 3500 mah will just make the phone a brick...
I had two extened battery for my previous phone one was a 2800mah and the othere was a 3500 they were both the same size i will buy both and make a comparison
That's a 700 mah difference which is not possible too much of a difference the battery would be unstable if not increasing the physical size. And there are many extended batteries from sellers claiming they are 3600 mah or so while many times they are just selling crap that isn't really what they claim it to be. Additionally many of these so called batteries that are 3000 mah or over are usually worst than stock batteries. So I am pretty sure if batterybay makes a battery that's 3500 mah it will be bigger if it's actually going to be what they claim it to be.
The oem premia battery is 1650mah so the 3500mah battery should be twice the size of the oem how will that make my phone a brick. I email ontrion for specs and batterybay.com
I would say bigger than that my 2500 mah battery came in today, I'm exited. And it's really twice as thick, so a 3500 mah will be pretty thick. A brick is a exaggeration obviously you should know what I mean.....
I got both manufacturers emails there are both twice the size of the oem except one is 2500mah and the othere is 3500mah the only difference.
I'll just stay with my previous comment until the battery comes out or if it comes out... :smokingsomb:
