i developed small application..
BatWid - Battery Widget
Show battery information with various type widgets..
BatWid is a simple widget (1x1) for battery status. It is include 10 kind of battery level image with animation when charging.
Tapping on widget will show battery information and options screen for change widget type.
Adding Widget : Tap and hold your finger on any available space, select "Widgets" and then select "Bat Widget Normal"
BatWid On Google Play
