BBCiplayer works on my N7 straight from the Play store.
Perhaps you haven't updated to 4.2. The BBC iPlayer is not currently listed as compatible with 4.2 (it says "2.2-4.1"); you can't install it from the app store using 4.2.
My N7 is fully updated although I did install iPlayer before 4.2.
Sideloading - the trouble is getting the app in the first place. How do you buy an app and download it to a pc instead of the nexus?
does it work on your Nexus 7, because it doesn't on mine, I just get a pink spinner whilst the video preview sits there. It never loads the video, even though i'm on 10MB wifi.
Of course it works on my Nexus 7, I wouldn't have posted otherwise. Actually the old one worked fine as well but you had to go through hoops to install it.
Perhaps you need to update the BBC Media Player as well if you haven't already done so, it's the bit that actually does the work without a separate need for Flash. The iPlayer app is just a front-end to it.
https://play.google.com/store/apps/details?id=air.uk.co.bbc.android.mediaplayer
