******* ROMs *******
______ Concord 2 _____
_____ Zte Z730 _______
_Metro PCS / T-Mobile _
****** OS JB 4.3 ******
WARNING! ANYTHING YOU DO WITH A ROOTED PHONE HAS A RISK OF BRICKING IT. USE THIS ROM AT YOUR OWN RISK! I AM NOT RESPONSIBLE FOR PHONE DAMAGES CAUSED BY YOUR PERSONAL NEGLIGENCE!
This is NOT a themed ROM like my other JollyRoger Roms, but it's further debloated a bit & I"ve done a few other things @The-Truth 's request to give the Stock Rom a better edge. I hope you guys enjoy it:
~ Added init.d/insecure Kernel
~ Init.d Scripts:
* SD R/W increased from 128k to 2048k.
* Cache cleaner cleans every couple days automatically
* Zipaligner auto zipalignes app folders every cpl days.
~ Classic JollyRoger boot animation ported to fit the Concord 2.
~ V4A - ViPER4Android FX EQ!
~ Es File Manager - Highly customizable!
~ CM Kobalt Themed Calculator. (with Holo switch). Scientific Calc with graphing abilities equivalent to a Ti-83!!
~ Threw in a few extra Cyanogen Ringtones as well
__ Special Thanx to __
- @SuperR : For giving me the tools to make this ROM possible!
- @The-Truth : For testing and asking this Rom to be made in first place
- Gunthermic2: for his Darkhorse APK's
Get more Dark horse APK's here:
http://forum.xda-developers.com/showthread.php?t=2163866
- slaid480: for his Fly-On-Modz init.d scripts that make this ROM better. Check out many more here:
http://forum.xda-developers.com/showthread.php?t=2226373
- zhuhang: for VIPER4Android FX eq. Wanna learn more about the insane capabilities of this apk? Right here:
http://forum.xda-developers.com/showthread.php?t=2191223
-INSTALLATION -
* CWM, TWRP, & Philz recovery can be used to flash this ROM.
* Be sure to factory reset & wipe both caches before ROM installation to prevent issues.
* Install J011y Xper!ment
* Reboot & enjoy!
Download:
J011y Xper!ment ROM - https://www.androidfilehost.com/?fid=24052804347823118
FOTAkill installation instructions:
* Reboot to CWM Recovery
* Clear BOTH cache and Dalvik cache (Dalvik is in Advanced menu)
* Install the FOTAkill.zip
* Reboot and enjoy!!
EDIT: IF you still get a system update notification, just select to install anyways (to release the nag trigger). The reboot timer will countdown but not reboot. Don't worry because the Update.zip was deleted when wiping caches in recovery and won't boot to recovery anyways. Manually reboot and you should be update nag free!!
FOTAkill.zip - https://www.androidfilehost.com/?fid=24269982087021816
* If you like the work, hit thanks in the OP's! *
~ Init.d Scripts:
-INSTALLATION -
* Reboot & enjoy!
Download:
