Help Beats Audio Headphones?
Wanted to get some new/good headphones/earbuds. Any recommendations? Also do the beats audio earbuds work on android. I mean like the microphone and buttons to answer/skip/pause songs.
Well I think beats audio is a little gimmick. It makes sound slightly better but price wise they aren't worth it because they're so expensive. Yes they work on Android since they're still headphones. Not 100 percent sure if the buttons work but they should! :D if you decide to root and install a custom rom most have beats audio already on there. That's what it is - just a fancy sounding equalizer.
And the equalizer actually can help audio. The headphones sound like a gramophone with a dog sitting on it.
Any high quality headphones will work quite well with this phone, it has pretty good audio hardware including a Wolfson dac instead of the much more common and cheaper Yamaha. Instead of worrying about Beats audio being included in a rom you'll be much better off by getting a good 3rd party media player such as Power Amp, Jet Audio or Neutron Player.
I just bought some Earbud Skullcandies and they are nice and loud, costed me $7.99. Though you can go cheaper and buy a couple of the iPhone/iPod earbuds from Amazon that are also nice.
i love the skull candys ear phone those are good to me if you love listening to music that has bass. cheap for like 30 bucks depend what kinda you want.
beats are pretty cool hd sound but the price are rediculous.
if your going to get one. get the SOLO!
