I have a droid charge. When I use either a beautiful or fancy widget of clock/weather, usually a few hours later it doubles itself. It seems to duplicate itself as an overlay. Ay suggestions?
Is it just those widgets or do all widgets/apps think that you're in the wrong location?
Go into settings > applications > development and make sure mock locations are not enabled.
If not, go to settings > applications > manage applications > Beautiful Widgets > Clear data. That'll fully reset the app. See if it's still like that.
If you still can't get the right location, go into Beautiful Widgets settings > advanced settings > and click 'Force GPS'. This will use your GPS radio instead of using AGPS (cell phone towers / wifi routers) for location.
