Beautiful widgets heeeelp
ChryzaorFlux
Ok straight to the point
Basically i cant use my toggle widget skins, they are in the correct folder
(sdcard/data/beautifulwidgets/tskins)
My weather, super clock and home skins all work
When i want to change the skin I cant see anything
Any solutions?
Is anyone having the same problem?
Hello and welcome to Android Forums. You best bet would be to ask your question in the sub forum just for your device. It appears that you are accomplished in navigating the site but if you have any problems.. just return here. Best of luck and I hope you find a solution to your problems.
Any solutions?
Your toggle skins are in the correct folder. However, make sure of the following:
(using the Aqua skin as an example)
1. That each toggle skin is in its own folder inside the sdcard/data/beautifulwidgets/tskins
2. That each toggle skin folder includes .jpg and .txt files named exactly as the parent folder (eg. Aqua.jpg and Aqua.txt files in the sdcard/data/beautifulwidgets/tskins/Aqua folder). Each toggle skin folder should also contain various named .png files.
The Auqa.jpg file is a thumbnail of the skin and the Aqua.txt file is a description of the skin. I've attached a .zip file of one of my custom toggle skins as an example.
If all of this is done correctly, try re-downloading the skins again and see if that resolves the issue.
Hope this was some help.
Thnx ardchoille, it works now
The text document was labelled "skins" instead of the name of my toggle skin eg "WhepeshBrue"
Nice Sense toggle skin looks great
Many thanks
Kid_android
Many thanks
Kid_android
Yeah, I figured something was wrong with a filename. Glad that worked for you :)
By the way, if you would like to make your own skins the BW developers have released a skin dev kit. This dev kit makes it easy to create you own BW skins.
